My MF100S bathroom extractor suddenly stopped working and I decided to replace it with MF100T using the same wiring light switch connections, means using switched live and neutral wires. I also used a small piece of wire to connect live and switched live port, (from right hand side of the circuit board), together but it is still not working. I am not using a timer. In MF100T there are three port connections, and I connected live and switched live ports from right to left and neutral on the left hand side. Could you please help? Somewhere, I read, the JP1 cap needs to be removed, is the ok? Thanks
