D
Deleted2797112
I need to replace a handle on a composite front door. The locking system has three bolts that shoot into the frame plus the key-operated lock. The way the existing handle works is that to lock the door, you don't need to use the key. You just pull the handle up to the 12 o'clock position and it locks and the handle returns to the normal 3 / 9 o'clock position.
I've tried looking for a handle that works this way but have only found the type where the handle remains at the 12 o'clock position when you lock it - I think these may be for sliding doors? I've also not found any handles that have the same screw centres so I'll have to drill new holes.
I've measured the centre spindle to centre lock barrel and it's 92mm so it's a standard size. Will any 92PZ handle work or is there a specific product that does what the existing handle does? TBH I'm not that fussed about having to lock the new handle with a key but just want to make sure I get something that locks the door.
Thank you!
View media item 90647
View media item 90648
View media item 90649
Thank you!
