Yes at 22 watts it is going to be about half the light output of a 58 watt tube.fluorescent lights
Is this for aesthetics only or is there a practical reason for not using something like This
Both ascetics and efficiency.fluorescent lights
Are the LEDs replaceable on the panels or do you replace the whole panel? If the whole panel is replaced it seems a lot more expensive option in the long term?Both ascetics and efficiency.
The light from LED Panels is mainly "downward" - NOT at the 180 to 270 degrees of LED "tubes" nor at the 360 degrees of Fluorescent Tubes.
LED Panels are likely to last for many years longer than Fluorescent Tubes, as are LED Tubes.Are the LEDs replaceable on the panels or do you replace the whole panel? If the whole panel is replaced it seems a lot more expensive option in the long term?
This: https://www.cef.co.uk/catalogue/products/4837549-28w-5ft-led-steel-batten-fitting-4000k if you want something equivalent to the single 58W fluorescent you have got now.I just want to make sure the wiring is going to be as easy
Good luck finding any.Just get another fluorescent.
Yes that is what I did, I swapped a 65 watt fluorescent tube for a 58 watt tube, and the ballast did work, but tube life dropped from around 4 years each to 6 months, so I fitted a 22 watt LED, which worked, but around half the lumen as @winston1 says, but to my mind that was enough, I could not easy access the fitting, so the tube change made it easy.Yes at 22 watts it is going to be about half the light output of a 58 watt tube.
not sure on size of each down light, but he is using more power for the same amount of light, however it is a high ceiling, so there is room for the light to spread, and store his wife's bike.LEDs are pretty unreliable in my experience.LED Panels are likely to last for many years longer than Fluorescent Tubes, as are LED Tubes.
It is an "Efficiency versus Life Span" question.
Could you explain why a 'tube' used in one fitting is good, but "junk" when used in a different fitting.Led tubes which can be shoehorned into fittings designed for fluorescent tubes are junk. Do not buy.
Depends on what you have been buying.LEDs are pretty unreliable in my experience.
Thank you, I understand the direction you are coming from now.Tubes have the LEDs contrived into that shape, which means they have little or no thermal management, will be limited to being in a single thin strip along the centre of the tube, the placement and quantity of individual LEDs cannot be optimal and the LED driver is shoved into that tube with the LEDs so it can overheat and fail.
Most also require adjustments to the wiring within the fitting.
Those designed specifically as LED fixtures such as those linked to above have LEDs on a wide aluminium plate for cooling, and the individual LEDs are positioned on that plate to provide the proper distribution of light.
The LED driver is a separate component, so any heat from the LEDs won't be directly coupled to it.
There is no 'tube' involved.
I can say without much fear of contradiction most do not last that long.At a fire station in California, the world's oldest light bulb has been burning for 118 years. By now not only the light bulb, but also the town Livermore are famous and are even in the Guinness Book of Records.
Not at those prices would i consider them........"These Days" you really should consider using "LED Panel" lights, rather than replacing "Fluorescent Battens" with something which looks like them !
(e. g. https://www.lights.co.uk/led-panel-lights/ )
