we have recently moved into a property with the old style wylex consumer unit with wired fuses. As i am planning to do various bits of diy i wanted to be able to switch off individual circuits at various times so i thought i would replace the old wired fuses with mcb's that seem available for cheap on ebay.
house is 2 bed with around half a dozen sockets per ring main and 3 lighting roses per floor
the consumer unit has a 60amp trip switch between it and the meter
the board itself has 2, 5amp fuses, for upstairs and downstairs radial lighting circuits,
3 ring main cirucits (upstairs downstairs and 70's kitchen extension)
and a 30 amp fuse for cooker socket.
what size should i replace them with-? when I've looked, the mcbs come in 6amp(presumably to replace 5amp radial)16,20,30,32,40 etc
however, of the 3 ring mains fuses, one has already been replaced by a 40amp mcb and the two remaining have 15A printed on the fuse holder? should i replace these with 16A mcbs or can i replace them with 30A or even 40A mcbs(like the one already there)
i'm confused as to why the old fuses are rated as 15A as i thought you chad 30 A on a ring main?
thanks in advance
thanks in advance
