Looking to replace 12 old style single radiators including the bathroom, would it be best to replace them with modern like for like singles or should i fit doubles instead?
I've measured the sizes of the existing radiators so was going to purchase the new radiators based on that as I don't really want to go down the route of adjusting the widths of the pipework
Should i stick with singles or install doubles? I'm guessing if i went for doubles the rooms could get a bit too hot, but the trv's could address that?
I replaced 10 old radiators last year. The way I approached it was, if the existing room was sufficiently heated, I replaced with the same size. Modern radiators have slightly better output for the same size vs older rads, so you’ll get slightly increased output anyway.
For rooms which I felt weren’t getting enough heat, I replaced with bigger. One room I got a slightly taller single, and in 2 rooms switched to a double. As you say, any oversizing here is taken care of with the TRV.
I also had researched the capacity of my boiler vs current heat output, and knew I had plenty to spare and wouldn’t overwork the boiler. I would not think/recommend replacing all your rads with doubles is a good idea for this reason.
This has worked great for me - no issues anywhere. Personally I wouldn’t bother looking into btu when you can just work off the existing set-up. Apart from assessing the output of your boiler that is.
