I have a leaking Myson One-Way TRV on a radiator that is leaking from the pin fairly consistently, so I am planning to replace it. This is probably the most advanced bit of plumbing I will have attempted to just wanted to get some advice from more sage members.
1 - I am replacing it with a Myson 2-Way TRV, which is a 15mm valve - however the pipes going to the rad are 10mm. I have bought a 15-10mm reducer but have no idea how to fit it. Would the order of components go like this:
Nut onto the 10mm pipe -> olive on next (the one that came with the 15mm valve) -> reducer -> valve -> tighten the whole thing up? I've tried to assemble it this way as a test and it seems like the reducer is stopping the nut from being able to reach the thread on the valve. Do I need another kind/size of olive?
2 - Should I be applying some kind of jointing compound or PTFE tape when putting the new valve on?
3 - Anything else I should be aware of? I'm hoping that the fact that there is already a 15mm Myson valve on the rad means that it should just be a fairly simple swap job but I know the current leaking one is probably about 18 years old so the spec might be slightly different.
PS the system will be fully drained down when I'm doing this.
