How do I take a feed from an existing light to a new light and double switch.
One light is in the hall, and the other in the living room (used to be the hall)
I have fed a wire from the living room light fitting to the hall (new Light fitting)
fed a wire from new light fitting to the switch
the wire from the living room light to switch is still there and will still control that light.
taken out old single switch and want to replace with a double switch, left side to control hall light and right side to control living room light.
wire
Neither light is to be dependent on each other
The new switch has L1 L2 at the bottom and C with C being at the top,this is repeated for the other side of the switch.
Do I need to loop the switch anywhere, and i seem to have a spare cable at the living room light fitting
wire
