Over the last few weeks we've noticed the pressure in our boiler has been rising and the pressure release valve has been dripping. Its been getting worse : I drained off a bowl of water at the weekend and the pressure was down at 1.5 bar. By the evening it was at 1.8 and back to 3 bar by the following afternoon. This has gotten worse over the last few days, and I'm now draining off 2 bowls ofcwater a day. Obviously the excess water is coming from somewhere, the filling loop is disconnected so the only thing I can think is a leak in the plate heat exchanger letting some water enter the system through the dhw supply. Does that sound a reasonable assumption?
I want to get this sorted asap as its getting worse by the day, and I'm worried it will damage the boiler. I've been let down by 2 plumbers, so decided to order a replacement part (even if/when a plumber does turn up - may as well have the part here!). But it doesn't look like too difficult a job, so am considering doing it myself. I should point out that whilst I'm no heating engineer, I have some plumbing knowledge and a mechanical background - certainly if it was on the oil/burner side of the system I'd not touch it.... So am I missing something, or is it a relatively simple job for a diy'er?
my plan is:
- power off boiler/turn off water supply
- drain system
- remove front cover
- undo nuts on existing plate heat exchanger
- connect up new one
- flush system through couple of times
- add inhibitor and refill system
Sound right? presumably there won't be anything which needs adjusting/balacing? The new part comes with washers, presumably the joints will seal with these washers, and I dont need to use ptfe tape/gasket paste?
my plan is:
- drain system
