Replacing Radiator
  • Thread starter Thread starter chesketh
  • Start date Start date
C
chesketh
I need to replace the bathroom rad, as its got very corroded on the outside, and looks terrible. I was going to fit a towel rad, but cant be bothered adjusting the pipework. Measured the Rad and its 700X925 which is I assume an old size. Not bothered on height, would be happy with a 600, but its the 925 width. Does anyone make these anymore, CH was fitted years ago, and was an open system orig, converted to a sealed approx 6yrs ago, but the old Rads and fitted left on I assume. If not, is there any way of extending the tails slightly to make up for the 25mm difference. I assume its an older union fitting, and not a compression, but never had this rad off, but the others seem to be a large nut to connect the the radiator tails. I can provide pics if you want
Cheers
