Replacing Surface Mounted Pneumatic Light Switch
17 Apr 2009
Sussex
Perhaps somebody can advise, it's a Victorian conversion with 2 flats, there is a pneumatic light switch in the hallway that is surface mounted and sticks out uglily into the hallway and we would like to recess it.
But I am wondering why it was surface mounted in the first place, there seems also to be a patch above it as if there had been a previous socket above and then it had been moved down.
That corner where it is on seems to take quite a high structural load and not sure if its too clever cutting out a square to recess it ?
Thanks for any advice.
full
full
You could replace it (them, if there are several) with an electronic equivalent such as
http://new.abb.com/low-voltage/prod...ay/timers-switches/standard-push-button-timer
More reliable, more attractive, and doesn't go "clunk" when it switches off.
Yes that would be absolutely fantastic ... the question I have is : am I safe to cut into that wall and recess it behind where it currently is ?
Or could there be a structural problem ? Or could there be a secret reason it was surface mounted aside from laziness ?
