Basically currently have a heritage exposed deluxe thermostatic valve (think its that as looks like it - previous owners fitted it).
The spacing between the inlet pipes coming out the wall is c. 145mm.
I want to replace it because
a) its currently functioning more like a 'random water temperature generator' flipping between hot and codl water.
b) it sticks out a long way (around 175mm) into a small shower enclosure and so would prefer a bar type that gives you a bit more space!
Probably will replace the whole shower room in couple of years so just looking for a quick fix for now which will sort those issues.
I had a grohe G1000 at my last place and think it's ace for constant temperature so am thinking of getting one - or at least the equiavelent one to it at Screwfix as its on offer. Also know it's slimmer to the wall. more like 100mm.
Big question is when I look at the installation documents it says the inlet pipes are 150mm +/-15mm.
Numpty question time...
Know, the grohe unit is a solid unit so I don't fully understand how you have variation in the feed pipes width, although my feed pipes are at 145mm so if I could get it to easily fit then that would be great. Could someone shed some light on what it means in the installation docs.
