Replacing Timeswitch & Immersion Switch
15 Oct 2005
Cheshire
Hi
I am thinking of replacing my ageing mechanical timeswitch for a newer digital programmer. At present the timeswitch operates on a single channel basis as I have a Gloworm boiler which heats the water & rads. I also have an immersion heater with a switch that can be used indepedantly of the boiler to heat water for instance in summer when no rad heating is required.
What I propose to do is replace the above with a dual channel programmer whereby the CH side would be connected to the boiler & the HW side connected to the immersion heater. This would allow me to use the immersion heater in summer on a timer programme without the house getting warm.
What do you guys think ? Is this feasible ?
Any help would greatly be appreciated.
Regards
Scott
This won't work without a relay.
For this you need an immersion heater timer - a CH/DHW programmer will not take the current required for an IH element, unless you use a relay.
I think it's a weird and cheapskate solution.
I recommend that you buy and install proprietary products.
I advise you don't use the Immersion heater at all. Use the gas boiler to heat the HW, it's still cheaper.
Your system may or may not need modification to let you do that without the CH .
