Replacing TRV spindle
11 May 2007
Powys
Hi all you pro plumbers out there. A couple of my TRV's are starting to weep slightly around the spindles. Is it possible to repair / replace just the spindle, or do I have replace the whole spindle assembly?
TIA
TRVs don't usually have spindles :?
are they ordinary valves?
Or do you mean the pin?
A photo will help.
Is there a small brass nut round the bottom of the spindle?
Hi JohnD,
Sorry didn't know what they were called - I guess its the pin. Its a Myson model fitted about 10 years ago. Sometimes they get stuck in the closed position as well.
looks to me a complete valve replacement is best bet
Thanks twgas,
If I replace the whole valve, will the joint between the micro bore pipe and valve body remain water tight afterwards, or do I have to solder a new tail extension onto the existing pipe with a new olive?
microbore :(
you can get 8mm and 10mm reducers that fit into a 15mm fitting instead of an olive
you can also get microbore-sized valves
I have never used either
I am just a householder
Clean all the paint off with wire wool
if it is difficult to seal you can use LSX as if it was jointing paste.
