Bulldog TRV stuck
22 Nov 2008
Yorkshire
Hi all, on the radiator in a spare bedroom, the radiator is very hot and it won't turn down with the TRV. Husband has taken the cap off, tapped it and tried to get the spindle (is it a thermostat?) thing to move but it won't budge. We've had it on 0 and the snowflake setting but it's still hot.
Anything else we can try? I did wonder if we can get a new spindle thing for it, but how would we fit it? Or is it a whole new TRV that's needed?
Hopeless at anything D.I.Y so any idiot proof replies would be great! TIA.
Sounds like a new trv head needed
A new head will not help if the pin is stuck in the valve body.
OP
Remove the head
Give the side of the body a few hard taps then check if the pin will go down when pressed.
Repeat a few times.
Next, try putting some light oil down the side of the pin (silicon lubricant is best, but WD can be used sparingly) and check if the pin is freed.
If no luck, turn the valve at the other end right down then open half a turn (remove plain cap to access spindle).
Get the TRV changed.
OP
Remove the head
Repeat a few times.
Never known the pin to stick open...:)
A sharp tap sometimes releases the pin when stuck shut , especially when pin is flush with body.
Why tap the side of valve for a pin that is fully open??....:rolleyes:
The OP wrote:Husband has taken the cap off, tapped it and tried to get the spindle (is it a thermostat?) thing to move but it won't budge.
If it was a head problem, hubby should still be able to press the pin down and it will move up when released; but he can't do that. As the rad is permanently hot, the logical conclusion is that the valve is stuck open. I know that's unusual, but it's not impossible. Corrosion round the pin would make it stick.
Thanks for the replies, hubby has tried all the suggestions but it still won't move. There's only a little bit of the pin stuck up he says no more that 1/4 of an inch, so he can't get a good grip on it.
If we need a new TRV, what does that entail? Do we have to have the rad drained? (I'm just thinking of moving furniture here lol) We'd have to get the gas chap out to do that though if it's complicated.
FFS....If the pin is physically stuck and won't move under manual pressure.
Changing the head will achieve fook all !!
You're right of course, why waste almost a minute testing it when you can simply spend a morning replacing it?
