Replacing uPVC windows...
7 Jan 2014
West Glamorgan
Tried asking in Windows n Doors, no response, so trying here.
Our house is a timber frame, and when only the frame was up, the windows (uPVC) were fitted externally into timber 'cavity closers'. The brickies then bricked up, and the plasterers skimmed up. I'd like to change 2 of the worse ones (in en suites, so quite small).
What method would I use to replace? Would I hack off outside render and fix from outside; or hack off some pb and fit from inside? Thanks.
First question, why are you replacing them? You do know that you can replace just the panes, if that is the issue and, pretty much all parts can be purchased individually if need replacing.
That said, if you're really intent on replacing then I'd probably work from the inside, plasterboard is easier to reaffix than render, for a DIYer.
