    Dismiss Notice
Replacing water supply
Discussion in 'Plumbing and Central Heating' started by TonyS82, 23 Jun 2020.
  1. TonyS82
    TonyS82
    1 Mar 2011
    96
    Thanks Received:
    2
    Essex
    Country:
    Hi
    We need to relocate our internal stopcock and will be taking the opportunity to upgrade the old pipe to 25mm or 32mm mdpe.
    After speaking with ESW I am happy with the work involved and what i need to do to get the new pipe from the boundary into the house.
    The inspector also said if it was him he would run the new pipe to the closest part of the house and then run the pipe in the void below the suspended floor to the kitchen. He said it was fine to insulate it and lay it on the ground. This would be a run of about 12 metres.
    Is the pipe likely to move around under there? If so i would like to clamp the pipe to the underside of the joists and through the brick pillers.
    What spacing would the clamps need to be at?
    Also, can you tell me the best way to clamp the insulated pipe? I can only find standard pipe clips but that would mean cutting the insulation around the clamps.
    Tony
  2. Alec_t
    Alec_t
    18 Mar 2017
    758
    Thanks Received:
    132
    Wales
    Country:
    You could make some from plastic or metal strip.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. denso13
    denso13
    22 Jan 2007
    5,632
    Thanks Received:
    1,118
    Country:
    • Thanks Thanks x 1
  5. TonyS82
    TonyS82
    1 Mar 2011
    96
    Thanks Received:
    2
    Essex
    Country:
    Thanks gents. Never thought of that
  6. Sponsored Links
  7. Elkato531
    Elkato531
    22 Jul 2009
    1,091
    Thanks Received:
    277
    Sussex
    Country:
    Hammer staples into the joists and use cable ties.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
