For a couple of months my central heating circulating pump (Wilo Gold-D) has started getting rather noisy, everything works fine (all radiators and hot water heat up as expected). I tried bleeding the pump in case any air had got in there but there was no sign of any and so this unsurprisingly made no difference. Therefore I guess the bearings in the pump are on the way out and would rather replace the pump now rather than wait for it to die completely – nicer to do it at my leisure rather than as a mad panic when we’ve got no heat or hot water (plus the sooner I shut the thing up the better).
I figure if I'm going to go to the cost and effort of replacing the pump I may as well put something decent in, reading this and other forums Grundfos seem to have the best reputation so I was looking at the Alpha 2 as it looks like it should be very quiet and be able to save a few quid on the leccy bill too. Is this a good choice?
The whole system is original and as installed when the house was built in 1998 and consists of: Ideal Classic FF240 conventional boiler, 10 rads (all with TRVs) plumbed with microbore tails, hot water cylinder (via mid position valve), Wilo Gold-D circulator (for now). There is a manual bypass valve installed (or at least I assume that is what the manual valve in the 15mm pipe that appears to 'short-circuit' the primary circuit is? - see pic below). Last weekend I put Sentinel X400 in the system to give it a bit of a clean and will drain it down fully in a week or two, fit the pump then refill including X100.
If I go with the Alpha 2 would the factory set 'Auto-adapt' setting be the correct one for my system?
Since the Wilo-D doesn't seem to be a current model finding specs on it is a little tricky but I did find one reference to it being rated for 5m head. I can get the Alpha 2 15-50 or 15-60 at about the same price (from different places) I guess either would work but would there be any advantage of either one over the other in my scenario?
I'm curious as to the point of the 'night set-back' function of the Alpha 2 which apparently runs it slower if the feed pipe temperature drops (e.g. at night), but surely the pump is controlled by the boiler or the mid-position valve (which in turn is controlled by the room stat, cylinder stat and programmer) so what's the point in it (i.e. if the hot water/rads are off at night then the pump will be off anyway)? Also it says that this setting is disabled in the event of power loss - again surely power will be cut to the pump repeatedly throughout the day each time demand is satisfied? Do some systems therefore pump constantly (even when there is no demand for heat or water) or am I just being thick?
A picture paints a thousand words as they say so here's the setup in my airing cupboard (I think it's pretty bog standard):
By the way what's the round grey junction box at the top of the image called and what goes on inside it? The pipes go up to the F&E cistern in the loft so I suppose it’s the equivalent of an 'H' join between the fill land expansion pipes, just curious.
Sorry for the long post, I seem to have rambled on a bit but any comments greatly appreciated, thanks
Jez
Jez
