Replacing wooden joists with concrete
4 Feb 2012
I'm looking at installing under floor heating.
My builder has recommended to replace all of the floor joists under the living rooms x2 and hallway with concrete.
We have a crawl space under the house so there will be a lot of hardcore and concrete to fill. Probably the perimeter is about 1.3m deep x 5m wide x 6m length.
Is this the usual thing to do?
I'm concerned with the side effects of doing such work
- will it effect neighbors property?
- will it cause walls to move or become unstable?
- will it cause damp if there is no ventilation coming from under the house?
- any other pointers?
Thanks in advance
Your builder is recommending you pour over 30 sq meters of concrete to a depth of over 4ft under about half of your house to install UFH.... change your builder !
You can’t do solid fill for that depth.
You could replace joists with bigger ones or sister existing ones then use a PUG / dry mix for your underfloor heating
or you could use aluminium platens
Thanks for the replies and details.
I should have mentioned, it wouldn't be just concrete - he mentioned there will be hardcore mot1, sand, membrane then insulation, concrete, UFH, screed, lvt
https://www.continal.co.uk/system/pug-dry-mix - this looks like a good find, thanks Notch7
