Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Recently installed a Premier Elite 24 system in my home. Had few problems but I cannot find out how to switch the 'reset after alarm' to user instead of engineer reset Can anyone help?
10 - Alarms Eng Reset
Each area can be programmed for Engineer or User reset following an Intruder alarm. Areas Assigned to ‘Alarms Eng Reset’ will respond as follows:
• The assigned areas can only be reset using an Engineer code
If ‘Anti-code Reset’ is enabled (option 14) the assigned areas can also be reset using the Anti-code
Areas not assigned to ‘Alarms Eng Reset’ can be reset with any User code that is valid for those areas.
I have the manual and have scanned that and note the references from Paul, but I can't find out how to change to User Reset from Engineer reset. I've gone through the menus but can't find the screen to change the setting.
