Here are the enforcement contitions
I've just noticed this,
Does this mean that a notice has been served? If so then it should state further details in terms of what they think is contravening planning policy.
You should then have something to go on to appeal the notice.
From the information here, I can't see how they can support their claim that residential use is established by way of a bed and bedding. Nor the other things as previously mentioned. Your use is more likely incidental use which would be permitted
The alledged breach of planning control
"Without planning permission, the unotherised change of use of stable block for residential use and kenneling"
Reasons for issuing notice
It appears to the council that the above breach of planning control has occured in the last 10 years
Policy CMS1 = Basicicly its outside planning area in green belt.
DM2 = Framework indicates that the conversion of modern purpose built agricultral buildings will not be supported (Dispite government policy to contary)(Its modern brick and tile built stables)
DM3 Indicates instances where general development in the countryside may be acceptable and mine meets none of the critera ( Never submitted bis plan ect)
