Hi All - this is my first post. I've looked at diynot alot, but not actually joined until now!
I'm doing an ensuite project and have reached the shower tray installation. I have a resinlite tray and need to decide whether or not I need to use the Easy Plumb kit I've been supplied with to raise the tray up (legs, baseboards, trim etc). I'm mounting the tray onto a suspended floor above the garage, and have easy access from underneath.
I'm wondering whether I can mount the tray almost directly onto the floor boards (maybe with 18mm of marine ply, and some cement to provide a leveling layer).
The drop for the waste is ample because I have 150mm joists - and the run is only 3m to the main downflow pipe. So the trap can protrude through the floorboards, and hang down into the joist cavity - and there will still be ample room for the waste pipe slope in the joist cavity.
So can I (should I) not bother with the raised installation (legs etc) and just mount really close to the floorboards?
Thanks in advance!
Thanks in advance!
