I have had to remove a yorkshire fitting for some pipework mods. Do i have to remove all of the old solder from the copper pipe before fitting a new yorkshire fitting. Access is a bit tight and the solder does not come off easily with wire wool. Will the old solder on the pipe mix with the new solder when heated.
Any advice would be apprieciated.
