Reson8 Bell Box with 4 wire feed
14 Nov 2011
Kent
I have just ordered a Accenta G4 control panel and a Reson8 bell box to update my current security system which has a faulty control panel.
The Reson8 bell box indicates a requirement for 5 wires however the existing cable from the control box position to the outside bell box position is 4 core and is built in so it would be extremely difficult to replace or to run a new 6 core wire.
If I use the existing 4 core cable is it OK to connect the strobe terminal (STB) directly to the bell trigger terminal (TRIG) on the Reson8 terminal strip.
With thanks
Twofirs
bit *****, but you can.....
However due to the extra loading on the bell panel output, i'd suggest running it through a relay.
