The cold water feed to my new shower comes off a very awkward junction. A t followed by a 90 degree and tight bend. I’ve no idea whether this will effect shower performance due to restriction of water flow??
if so, I’d like to reconfigure with some speedfit connections to enable a more straightforward connection.
Having read the posts referring to bonding and reading whatever I can find on the net, I believe I’m ok to cross bond the copper section of the pipes. Otherwise I can ensure the length of said pipe is longer than 1m. The latter is the preferred option.
it’s worth noting that I believe the cold/hot pipes are likely in contact in other areas and I won’t have access if I need to bond.
Thanks for your advice
