I went to a rented property today for a PAT test. Plugged in the tester and low and behold the machine showed a reverse polarity on the socket outlet. Took the socket outlet off the wall and the conductors are wired "correctly" but it is a spur. Did a visual check at the CU and it was wired correctly. So fair assumption that the other end of the spur where its taken off the ring has been wired in reverse.
The problem is this was in a kitchen and i think the spur was put in first then the kitchen because i cannot trace the spur connection back to any of the accessable sockets.
No junction boxes under the kick boards and no cut outs in the back of the cabinets.
So it really isnt practical to rip out the cabinets, what would you do. My first thought is to sleeve the wires at the socket outlet so the sleeves represent the correct colours for the conductors, and reverse them around so that thay are in fact correct polarity.
I know this is not the ideal solution but in a real world scenario is it what you would do.
