You have to have a sound engineering reason to do it. Just omitting it because of a cynical disregard for the regulations and a deranged hatred of the fact that they change leads you to not want to provide RCD protection is unacceptable and non-compliant.Yes, and what are those circumstances? That the socket is provided to supply a specific piece if equipment and is so labeled.
Yes it does - try reading Chapter 63.Whether you, I, or anybody else might consider it appropriate to omit the RCD if the piece of equipment would function perfectly well with it is immaterial to the question of whether it complies with BS7671 when BS7671 doesn't include such consideration as a condition of the exemption.
That is exactly what we are talking about because you are required to exercise reasonable skill and care when carrying out the design. Leaving off RCD protection because you just can't be bothered, or because you just don't want to do it is not reasonable, it is not skilful and it is not careful.We weren't talking about what you or anyone else considers to be best practice, only about whether the result complies with BS7671.
Wrong.As I said already, a cost vs. benefit assessment. It's one socket, provided with the intent of feeding a specific piece of equipment, for which the absolutely tiny increase in safety RCD provision would provide may not be worth the cost of such provision compared to just running a few feet of cable to a regular socket.
Again.
Wrong.You don't have to do anything.
Again.
You have to exercise reasonable skill and care in carrying out the design and that includes taking into consideration the nature of the installation and who will be supervising it.
No, but they are very much responsible for the provision of something which they know will later be in the charge of an ordinary person.Obviously the designer/installer cannot be responsible for what somebody might do later.
And I stand by that given that you must exercise reasonable skill and care in carrying out the design.To which your reply was:
ban-all-sheds said:Wrong.
Again.
It does not.But then after you said that you need some specific reason and I asked you if BS7671 actually contains any such requirement in the exemption clause your reply was:
ban-all-sheds said:It does not.PBC_1966 said:and ask again if BS7671 says anything about needing a specific reason.
But as a whole it does presume a certain amount of intelligence, integrity, professionalism and ability and willingness to exercise skill and care.
You cannot separate those. If you do something which is not a good idea then you have not exercised reasonable skill and care.Again, remember this issue arose not on the basis of whether anybody might feel that it's a best practice, a good idea, or anything like that, only whether providing a socket for a specific piece of equipment and so labeling it would be compliant with BS7671.
No, I would consider what is reasonable.Back when BS7671 required RCD protection only for sockets which might "reasonably be expected" to be used to power portable equipment outdoors, were you claiming that sockets even on the second floor of a building would still need RCD protection to be compliant unless you could be satisfied that they would never be so used? (Allowing for the fact that somebody could, quite easily, drop an extension lead out of an upper window.)
Were the second floor to be a maisonette or flat where the residents had garden maintenance responsibilities it might well be reasonable for them to drop an extension lead out of the window.
It could equally well be unreasonable for someone to eschew a suitable outdoor socket and use an indoor one on the ground floor.
You see, one of the differences between you and I is that I actually think about things, rather than put forward a simulacrum of real thinking which is actually nothing more than cynical rationalisation of decisions driven by a pathological aversion to complying with regulations.
