The clue was when you said the boiler worked OK with the front off,
the most common boiler with case seal is the good old Camray, most balanced flue boilers use the 80mm "snorkel pipe" as previously described
If you wish to find a time served Experienced engineer near you
send me a PM with your location I can then forward it to my UK network of "Trusted Service Engineers"
Blimey this is an old thread..Makes me realise how in need of a new boiler I am but can’t afford that at the moment. Problem is my Camray 5 Combi starts and then immediately switches off. The motor still running but no ignition. I replaced the photocell and put a new electrode in but the problem persists. One thing I did notice was that if I unplugged the photocell I would get ignition until a few seconds later and it cut out - as to be expected- but at least I got ignition……’Any suggestions would be greatly received. Unfortunately my local heating engineer has now doubled his prices so I’m reluctant to call him out - especially as it was only serviced 3 months ago. (On removing the burner I did notice a load of soot on the outside of the blast tube.)
