Hello, in my new extension being built with a floor areea approx 46 sq metres.I was going to install a new 2.5 mm ring main and the LABC will inspect and test it. My problem is that doing the measuring although the sq.meterage is only 46 the cable run will end up as nearly 80 metres due to the house layout. Is this an unacceptable length?Is this likely to cause a problem when they test?The rooms will be a dining area and a bedroom. Thanks in advance .
