My sister has bought a flat which has a very small kitchen and what I think is a dodgy electrical installation. The sink is in the corner of an L shape arrangement and has a gas boiler overhanging the end of the sink drainer. A switched fused spur outlet (feeding the boiler) and non-fused switch spur (feeding the cooker via a BS1363 outlet located under the sink) are located above the drainer. To make matters worse, the sink has a mixer tap that can be moved around over the drainer and opposite the switches. Is this legal? If it is it just looks plain wrong!
There are two double socket outlets near the sink - one about 400mm from the sink and the other about 400mm from the drainer but because the sink drainer is right in the corner of the 'L' it would be easy to use the sink and socket at same time (if stupid enough to attempt this). Again - is this legal? I can think that it would be easy enough to replace the latter socket with a blanking plate (leaving only two double sockets in the whole kitchen) but cannot think of any way of dealing with the spur switches. Is it possible to buy an off the shelf cover to give the switches protection against splashes? The switches are flush mount so buying IP65 rated switches (with their back boxes) is not a suitable option. Another thing I could do is build a protective box over the switches but this just seems wrong as it would hide the switches and if easily removable could be taken off and left off. Any advice would be appreciated as there are only two further options - redo the kitchen (nightmare!) or tell my sister to be careful (bigger nightmare!).
The only saving grace is that the kitchen ring main is protected by an RCD in the distribution box.
