Risco agility 2
11 Dec 2019
Have a risco agility 2 and one of the pir sensors (rwt92) batterys went low so changed, have now noticed the sensor led light goes off whenever it has movement its seems to have lost its sleep mode for a few minutes once it sees movement which makes me think its going to chew through batterys, is this likely to be a faulty sensor or can something within the sensor be adjusted?
Nick
Try again in half an hour or so, is it still behaving that way. If not then you need to look at the settings. Always a good idea to do a walk test to ensure all devices are working properly after any changes
It now seems to be working as it should with a sleep time between motion detecting, I guess it must take a while to reset. Thanks for the reply
