MY roof has 3 layers between the loft and outside, first a layer of felt which would not take any water outside the house, then a layer of polystyrene insulation followed by an air gap and then concrete tiles. Can anyone tell me what the purpose of the felt is as it only seems to channel the water as far as the inside of the external wall?
My other question is about adding additional insulation in side the loft. As the only venting appears to be directly under the tiles will it cause an issue to put additional insulation right up to the inside of the felt?
If it helps the house was built in the 1970s.
