    Dismiss Notice
Roof Insulation in Garden Shed -- Closed or Open Ventilation System
Discussion in 'In the Garden' started by mj62mj62, 6 Sep 2019.
  1. mj62mj62
    mj62mj62
    27 Jan 2010
    56
    Thanks Received:
    4
    Country:
    Hello,
    Shed roof insulation has been discussed on the forum before, but I'm stuck on one bit:
    Air Flow
    Please bear with me
    The shed is going to be a fully finished space for daily office and studio use.
    5.5m x 2.5m -- fairly large
    Sloped roof, felted
    Interior is a shell - we're saving by doing the interior ourselves.
    Roof insulation is the next step.
    The felt is already on so we're looking at a Cold Roof style, which I believe is:
    - Rigid insulation between the rafters
    - Choose a thickness of insulation that leaves 50mm air gap above
    - Air flows through vents from the front, through the gap, and out vents at the back
    Our rafters are 65mm and the insulation is sold in 25mm thickness, so I'm hoping a 40mm gap rather than 50 is ok... :confused:
    Our issue is that this is no air-flow:
    - the front soffit is completely sealed - no vents or air gaps.
    - the rear overhang is tiny and you can see it's not sealed well - light and air come into the roof cavity
    It seems the choices are:
    (A) Open the system - add vents at the front and back for each pair of rafters (that would need 9 vents in the front and 9 in the back - but there's no room in the back anyway!)
    (B) Close the system - seal up the rear where some air is getting in. Hopefully stop damp air getting into a place it can't escape from.
    (C) Leave it as it
    I just want to protect my investment from damp and keep it warm. Any thoughts?
    Many Thanks :notworthy: (y)
  2. mj62mj62
    mj62mj62
    27 Jan 2010
    56
    Thanks Received:
    4
    Country:
    p.s. there's a great video here explaining both warm and damp roofs.
    Relevant Cold roofs are covered from the 7 minute point and beyond
  3. Sponsored Links
  4. conny
    conny
    30 Jun 2008
    14,134
    Thanks Received:
    801
    Suffolk
    Country:
    Don't know much about ventilation but I would be inclined to fill the void completely, thereby eliminating the risk of cold, damp air become trapped between the insulation and underside of roof. If there is no wind/breeze blowing then there would ne no airflow to remove damp air in the void.
    Others with better knowledge may think differently.
  5. mj62mj62
    mj62mj62
    27 Jan 2010
    56
    Thanks Received:
    4
    Country:
    Just for anyone visiting this thread in the future, we ended with advice from an insulation specialist who advised:
    - Rockwool in both the walls and roof
    - Intello as a smart VCL (vapour control layer)
    - closing off the soffit areas with OSB+sealant because they were very airtight (the soffits were left as an empty space)
    - prior to insulating we sealed off all the edges as well such as where the floor meets the wall, etc, to ensure it was as airtight as possible
    This solution gave good insulation whilst also providing vapour management (drying to the interior) given the outside and inside cladding is thin and probably not perfectly airtight.
    It wasn't cheap but we were able to get everything we needed from baunativ in germany including instaabox's for the electrical outlets, etc. We could have put in a service void but decided it was more important to have the space.
    I like your train of thought and I had considered the same, with something like Celotex. However celotex themselves told us not to use their product in this situation. (probably because if anything does get damp, it cant breath/dry anywhere). From an effort and cost perspective, I understand it's fairly easy to cut celotex to fit and to seal with tape provided you get the really good aluminium tape. But having looked into it in detail, I feel the insulation specialist gave us a really thought-through solution for a building which we hope to have for many many years.
    • Like Like x 3
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
