Roof joists - alignment
30 Mar 2015
I am fitting the roof joists on my garden room and have selected a 9cm overhang at the back. There will be a ring beam at the end of this (4.5cm) which takes me to 13.5cm overhang. I will then have a 2.8cm batten on the wall.
The 10cm soffit will go against the batten, which means that there will be around 0.7cm of the roof joists exposed. Will the fascia capping return cover this?
Secondly, I’ve fitted the further most joists and then string lined them to make sure the others are touching this line. That will give me an equal overhang at the back unless there is some fluctuations in the back wall.
How do I level off the joists at the front? I don’t have any chalk line unfortunately.
Thanks in advance
Same way as the other end?
You don't need a chalk line, just a line.
On the back, I put the furthest joists in with the right overhang. I then attached a string line to these and played all the others against this stringline. They are now all aligned at the back. They are very slightly misaligned at the front. I am guessing my room is a cm or 2 different across the entire length. I'm not sure where I put the string line as all the joists are in place.
Cut the end two joists to the correct dimension (measure the overhang) then put a line on the top horizontal arris (use a nail or screw to hold it)
If any intermediate joists are catching the line then lift the end two slightly
I am referring to the length. Some may be slightly longer/shorter than others.
Yeah, you use the line to mark all the joists to length, plumb down and cut them!
If some are shorter then you need to add a piece
Simple as that!
I get it and thanks for bearing with me. Another thought, I have a red dewalt laser. Perhaps I can use that in the dark to mark out the line and then cut during the day?
Yes laser will do.
Remember to secure all the joists at the other end with their correct projection, so none of them move before marking.
Yes laser will do.
They are all screwed in from the back. I will screw in at front and then use the laser level. I was planning to cut with my circular saw
UPDATE: cut these and put the ring beam on today. Thanks for all your help.
