Hi
Trying to specify exact dimensions for my new roof trusses, and having fun and games with it so looking for any tips. Basically I took the 5 measurements requested by the truss manufacturer for the existing roof that I have to match (only matching the back as the front is stepped down) but I wasnt too confident that I could get these bang on because I had to crawl around in the loft and I don't think the existing roof is that consistent. So I mocked up a full truss to the dimensions of the calculated "match existing roof" truss and sure enough it was out by about 1.5 degrees which made a significant difference. So I corrected it and offered it up again and it seems good. I've been pretty thorough about checking the measurements of my mock up so planning on using that to spec the new trusses.
Anyway sorry for the ramble, but I've concluded that the only way for me to get a confident idea was to mock up a truss and try it. If anyone thinks thats a silly idea then any advice appreciated.
On a related note, I guess if you're trying to match an existing roofline with new trusses, then there's very little scope for correction if it's not absolutely spot on, I guess at a push you could double up battens/use deeper battens where needed or is that a complete no no?
