roof Valley problems
19 Jul 2011
hi folks i have a problem with our valleys on the house it a appears that the fibreglass valleys put in the 60/70 have split
i have had a couple of roofers round who have said they can replace them with new fibreglass ones
however i just what appears to be a roofer with lots of experience round (friend of a friend) who has said they valleys should never have been done in fibreglass due to the roof pitches
The roof pitches are 45 degrees and 30 degrees thus a 15 degree difference.
he has said they should be done in lead as manipulating the fibreglass ones this much they will crack and split. or a dry valley system may work but he would have to check out the pitch options for it
is this right and would i need it in fibreglass, lead or a dry valley system
cheers
jon
Manipulating the fibreglass ???? I'm no expert but don't they form the fibreglass in place, so it fibre and liquid until it sets so no problem with manipulating it anyway.
Personally I would be tempted to just put lead over the existing valleys (after removing any cement and replacing once the lead is in place)
right done some more research and got prices
i appears that the good roofer was right. fibreglass valleys can only be used on a 5 degree variance in pitch.
yes it could be done in lead and this would work out to be about the same price however this would mean on going maintenance on the mortar over years to come.
the dry valley system is designed for this type of roof and will cost about the same a lead as part of the roof needs to be relaid.
i have been quoted £1000.00 to replace 2 x 5 meter valleys and dropping a 8 brick high chimney below the roof line and re instate the roof.
he has also said when he opens up the roof he will look to see if the dry valley system is fully suitable and if there is any doubt he will do it in lead.
cheers jon
Peter1919";p="2530334 said:
Manipulating the fibreglass ???? I'm no expert but don't they form the fibreglass in place, so it fibre and liquid until it sets so no problem with manipulating it anyway.quote]
Not so in this case.
