Roof ventilation - loft conversion
7 Sep 2015
I am new to this forum so hello to everyone.
I plan to carry out loft conversion and have little problem with roof vent. I live in mid-terrace house. My roof is build from double roman tiles and bitument type felt below. When installing future insulation between rafters I need to leave 50mm gap between felt and insulation boards. All will be ventilated via continue eaves and ridge air gaps.
Now the problem: once I install new velux windows there will be no continuity in air passage from eaves to ridge. How to ventilate the space between rafters near new skylights?
7 Sep 2015
Just been advised by my architect that...'if building control ask for it we will provide some vents but nothing to worry about'. And this actually got me worried even more.
Any ideas please?
21 Jan 2007
Devon
You have to be pragmatic, you need to take reasonable steps but along your journey but there will be plenty of more important things to be concerned about. Fit a tile vent next above and below the window if you really want.
7 Sep 2015
Ok thanks for your good advise. I will try to have pragmatic approach, however its also good to know some theory behind. I ask people for help on this forum to get the pragmatic view so ventilated tiles is a good advise - thanks. I am aware that it is difficult to forsee all, hence I try to tick as many boxes as possible before starting on site. Roof is my particular worry as once I open it I would like to close it asap in case of rain. Thanks
3 Sep 2006
West Mids
Secure a few wedges in the felt laps to keep them open and allowing air flow within the void between the rafters.
7 Sep 2015
Thanks Woody, do you mean I.e. some plastic chanells between felt overlapping?
21 Jan 2007
Devon
full
7 Sep 2015
Much appreciated - easiest solution. I can't believe how simple this was and I spend hours trying to figure this out. Also nearly bought a vent tiles! Thanks again
