Room stat help required!! please ;o)
30 Jan 2006
Staffordshire
Hi,anybody able 2 help me my stats gone caput,ive brought a new one with 4 wire conection,but dont understand the wiring the old 1 was.....1=red,2-yellow,3=earth,4=neutral and the new 1 is not quite the same!! 1=common,2=satisfied,3=demand and 4 connect to neutral.tryd doing it the same as the old 1 and triped the electric ;o( any help would be greatly received if you could email me on how to wire it up would be fantastic !
If anybody can help...please do.
Kind regards
Richie (sitting in a cold house in stoke)
Take the yellow wire and put it in 3 [Switched live, demand]
Take the earth wire and put it to the seperate earth terminal marked with an earth symbol and NOT into 1,2,3 or 4
Red is common live and ok where it is #1
Blue is neutral and ok where it is #4
#2 Is generally not used
Please note that this is general guidance for most systems. If you are unsure then its best to get a professional in.
PS I would quickly put your email address in your profile and remove it from your post before the Moderator catches you.
Red to 1
Yellow to 3
Blue to 4
As Sluggy said why do you need to bypass to get heat. Just wire it up :x
Thats probably cos its double insulated and dont need one.
Why do you start if its quiet obviously way out of your depth.
Can I say it any simpler.
Red in common or 1
Yellow is switched live or 3
Blue is neutral or 4
Blimey ask your wife to have a look she will get it straight away!
If there is no connection for the earth that means it doesnt need it!
Just leave it behind the back plate or hang a picture on it.
when it cums to painting cars im very good!!!! when it comes to electrics im stuffed but when ur skint and cold i have a go!!!
so carm down :lol:
