Not sure if this should be in the Electricals board, anyway...
So, being a fan of electrical antiquities, two years ago I installed this NOS Ekco room stat to run a 1kw kick heater.
Probably 1960s.
Used it with a clockwork Horstmann time switch.
The wiring options for the stat were with and without internal heater, and as the load is below 8A, I chose with.
In operation, it cycles a lot. Switches off for a few moments then back on. Sparking across the points. Does that several times before it decides that it's done and really switches off.
Would it be less sensitive if I didn't use the internal heater?
Probably 1960s.
