Round windows
2 Oct 2009
Carmarthenshire
I want to make round window frames for... round windows! About 12inch diameter, double glazed etc. External facing. How should I go about it? Got a jigsaw. Ta.
You need to have a pvcu frame specially bent by a fabricator. Your jigsaw won't do sheite, lol
do you want to do them in timber?
conventional way is to make them out of 4 (or more) pieces with the right curve cut on them using a band saw. then jointed together and do the final trim after they are jointed using a spindle moulder or router running to a template..
jig saw probably will struggle to do the 50 to 80mm thickness required.
i dare say you could do something with layers of ply but durability will be questionable.
Well I've hit on the brite idea of.... layering. Not gonna use round glass but will put square bit in between 2 layers of 20-25mm wood squares (not decided what thickness yet), halved and half circle cut with jigsaw (laff away but I bet it'll suffice). Narrow wood strips, same thickness as glass, around the glass in the gaps tween. Screw the wood together. Hey presto, round window. Will add more wood to thicken. Mastic around the glass/wood. Fit into 'wall' I'm building.This is only for a shed/hut, it aint' gotta be flash. Thing with screwing is (no, not THAT kinda screwing) is if glass breaks/cracks in future, I just unscrew the inside wood layer and put another bit of glass in. Give me a couple of years hehheh, and I'll have pix on here for you to either laff or praise. Ta for tips guys. And no, I'm not on acid at the moment : )
