got afew rads that i cannot get a grip on with a rad bleed key any ideas how to get round this problem,i was thinking a very small socket????might have to to stick a small bit of metal in socket to get a grip,need help asap please
if you buy a new bleed key, preferably a brass one, that is unworn, it might fit. If it is still loose, stretch a piece cut from a rubber glove over the square pin, and it will take up the slack. Don't do that until you have bought new pins to screw in. You have to turn off the valves at both ends of the rad to stop water squirting out when you remove the pins.
The pins screw into a plug which can be removed and replaced by new, as described above. Yours may fit an ordinary spanner or wrench, or may need a radiator spanner which fits into the socket the pin screws into, and has a hole in the end to fit round a jammed pin. http://www.screwfix.com/p/radiator-spanner/11467?_requestid=158376
