Hi, I'm in the process of putting a plan together to run wiring around the house for a pc network, multiroom audio and video. The cables will be Cat5e, RG6 and speaker cables. Is there anything specific I need to be aware of for running these between walls (hollow plasterboard dividing walls), under floors etc.
Should conduit be used, if so do the same rules apply about capacity of conduit and number of wires. Is it better to use mulitple smaller diameter conduits or fewer larger diameter conduits, I'll be running maybe 20 wires from the main hub?
If I need to run wires across joists at a right angle is there a limt on the size or number of holes that can be drilled in the joist to feed wires through.
