RSJ sizes
21 Oct 2005
Middlesex
Hi, i am a newbie on here,
i need to Calculate the sizes of 2 rsj's needed to support a opening for a doorway and removal of a load bearing wall. i have tried using the software supabeam but the steel suppliers has said that the sizes are old and not made anymore. i have been quoted £500 to do the calcs.
any advise/help?.
hey mark,
i'm no expert but in my experience an 8 inch rsj is used for load bearing walls, doorways and windows on non load bearing not as stringent. In general youve got to allow 150mm on either side of it so just add 300 to your opening. The bigger the opening the more you should give the rsj. Hope this helps.
curadh
any advise/help?.
What sizes have you worked out? i can give you the size/weight equivalent.
Im imagining maybe a 203x203x52??
or 8x8
Yes, 203 x 152 is no longer available, the nearest (upwards) would be a 203x203x52 UC, and the 152x127 would be a 152x152x37 UC
Althought theses are the samee mass as the old sizes, the web and flanges may be slightly thinner due to the size increase.
For the 203x203, a slightly larger mass is available. 60kg/m, but for the 152x152, 37 is the maximum mass available.
They are the new eqivalent sizes, im not saying put those in your house, but if your happy with your calcs and the slight increase in sizes do what you will.I cant remember of the top of my head which grade has superseeded 43, i think its S275, but your supplier should help there.
http://www.corusconstruction.com/iframe.asp?indexID=55&URL=/spmc/SectProp/UC_SP_Frm.html
thanks for the reply's.
i will tell the building inspector that i will be using them sizes and see what he say's.
seams correct to me. thanks
There's nothing stopping you putting an over spec RSJ in place or pricing on that--cost alot less than £500 aswell
putting in an overrated rsj is ok but for the weight. i have been told that the 203x203x52 UC at a lenght of 4.55m would be about 250kgs. which is heavy enought to lift by hand.
Thats 550lb's !! How many Shredded Wheat do you have !???????? :shock: :shock: :shock:
236.6kg.
If you dont already know, when the size is written as 203x203x52
The 89 would be the mass, or weight of that particular size section, per metre length.
Eg 52 x 4.55 = 236.6.
As a fabricator, i deal with these a lot, nice light stuff like that is a pleasure to work with!
If there is no means of mechanical lifting, make sure you have plenty of mates on hand, even if it costs you a few beers!
IT IS NOT VERY DIFFICULT, I CAN HELP.........THE SIZE OF THE RSJ WILL DEPEND UPON THE SIZE OF THE OPENING....IF IT IS SMALL OPENING LIKE 1 TO 1.2 METERS YOU MAY NOT NEED RSJ'S ALL YOU WILL NEED IS ONE OR TWO CONCRETE LINTELS. SIZE OF THE OPENING IS VERY IMPORTANT AND ALSO HOW MANY FLOORS ARE IN THE PROPERTY AS WELL AS WHAT IS THE WIDTH OF THE WALL WHERE YOU WANT MAKE THE OPENING. IT YOU CAN POST THIS INFORMATION, I COULD ADVISE FURTHER......GOOD LUCK
Mark, from your post above you seem to be implying that the beam/s will be 4.55m. If so you need to be careful as the deflection of a beam that length can be considerable.
How exactly have you calculated your loads? Building control will not just want to see stress calcs they will also want to know how the loads were calculated and distributed as well.
Also - a slight aside - RSJs are no longer made in any form any more. The modern equivilant is a Universal Beam.
