Hi all,
we are having a bathroom installed in a new loft conversion. We were told during the initial survey that the water supply would be run up from the existing bathroom to the new bathroom above it.
The plumber didn't want to do that as it would mean disturbing the tiles. It was only 2 or 3 tiles that needed removing to get at the central heating pipes. The hot and cold were in a bathroom cupboard that was easy to remove.
So he took a feed from the pipes in the corner of the 1st floor back bedroom above the boiler in the kitchen, ran under the floor in the bedroom to a fitted cupboard, then up the inside of the fitted cupboard into the loft.
It was an easier and quicker way for him to get the water and central heating pipes into the loft. But that means the pipes now run diagonally under the middle of the floor of the new loft bedroom. I wondered if that is a good idea? I would've preferred the pipes to run from bathroom to bathroom or does it not matter? The water pipes have always been around the edge of a room wherever I've lived.
I've attached a crude diagram of the position of pipes in loft.
Also should the new shower, sink and toilet all have a stop valve on them?
many thanks in advance
