hi,
im running a spur up into the loft of a upstairs socket. pretty confident in doing all the connections but just to clarify.
connect 2.5mm cable into l/n/e in the socket on the ring mainand the connect the new socket same wherever desired. (not tested the socket but two wires going into double socket in upstairs bedroom, do i need to test to be sure? from what iv read it is more than likely on the ring main)
the problem im having is how to run the socket up the cavity etc.
any ideas on this or is this asking to much for a amatuer and shall i just run the cable along the skirting and up the wall
