Looking at the rules for running cables through joists to plan a run of cable, using this sourcehttp://www.tlc-direct.co.uk/Book/4.4.1.htm
I don't think any of the original wiring in this house complies with this. I've manages to get away with not cutting to many holes in joists, but where I am running some cables in some previously cut notches (where old CH pipes ran) I was hoping to cover with strike plates obtained from TLC. I take it that is still acceptable?
Next Q: When they say 25 to 40% of joist length from the ends, do they mean that the holes/notches must be cut/drilled BETWEEN a point 25% along the length of a joist and another point 40% along the joist? (10- 25% if notching). That is the way I read it, how many times is that not complied with I wonder?
So, they are indicating that the notching method is more acceptable nearer walls, but I would have thought that it is the most likely to cause structural problems in the joist. If drilling a hole is better for the joist, why not allow it nearer it's end-bearing?
JD
JD
