Running coax cabling beside mains cable
Discussion in 'Alarms, CCTV & Telephones' started by dg_pug106gti, 14 Dec 2019.
  1. dg_pug106gti
    dg_pug106gti
    16 Nov 2017
    68
    Thanks Received:
    Country:
    I am going to install some CCTV and needing to run the cabling from my loft to the camera at my front door.
    I already have a mains cable 1.5mm twin and earth ran down for soffit lights, can I use the same path to get the coax cable down or do I need to use another path?
    The system is Hikvision POC DVR and cameras.
    Thanks David.
  2. secureiam
    secureiam
    20 Jun 2014
    5,505
    Thanks Received:
    690
    Lancashire
    Country:
    the issue is interference, so it depends on how much is exposed and how long, try and keep apart as much as possible
  3. Sponsored Links
  4. dg_pug106gti
    dg_pug106gti
    16 Nov 2017
    68
    Thanks Received:
    Country:
    What I will do is just use the holes drilled from loft to cupboard and cupboard floor into the garage and I will separate it in the loft and in the garage so only real point of close contact will be in the holes.
    How far apart do the cables really need to be?
  5. sparkymarka
    sparkymarka
    16 Feb 2011
    9,006
    Thanks Received:
    1,375
    Sheffield
    Country:
    Be fine
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
