OK, i am a totally competent DIYer. I need to confirm what i intend doing is correct.
Just moved house, and had an electrics survey done as it is 1930s property.
Main concerns in the report recommend changing the various old bakelite and metal fuse boxes in the cupboard for a new consumer unit, and running new earths to within 300mm of the gas meter and stopcock.
I have no problem installing the consumer unit. My problem is that the house has solid floors, so no crawlspace, and both the gas and water enter the property on the other side of the house.
Is it acceptable to run the earth cables along the outside of the house at damp proof level?? If OK, is there a minimum height above ground?? Or should they be run in buried trunking of some kind???
Many thanks
Many thanks
