Agile said:A few weeks ago I saw a hob unit that had been connected to the gas with a flexible cooker hose!
Tony
the gas cooker would normally be fitted with flexi hose and the hob rigid and an isolastion valve below the twonstreet said:Agile said:A few weeks ago I saw a hob unit that had been connected to the gas with a flexible cooker hose!
Tony
We had a new kitchen fitted some four years ago now, the corgi man said it was ok to fit the hob with a bayonet fitting and flexi hose as it is easier when it comes to replacing the hob.![]()
B.O.B DOLE said:the gas cooker would normally be fitted with flexi hose and the hob rigid and an isolastion valve below the twonstreet said:Agile said:A few weeks ago I saw a hob unit that had been connected to the gas with a flexible cooker hose!
Tony
nstreet said:B.O.B DOLE said:the gas cooker would normally be fitted with flexi hose and the hob rigid and an isolastion valve below the twonstreet said:Agile said:A few weeks ago I saw a hob unit that had been connected to the gas with a flexible cooker hose!
Tony
Was the way he did it against the regs then? By the way the oven was electric
Agile said:There seems to be some confusion here.
In all normal situations a hob has to be fitted with rigid pipework and NOT a flexible hose.
nstreet should telephone CORGI if he wishes and they will send their inspector who will cut off the supply to the hob and label it with warning stickers and then fill in a RIDDOR form and later discipline the installer.
Tony Glazier
MOD
last warning
item 12 [/quo
if you fit a hob only its rigid but if you have a gas cooker has well you can fit the hob with flexi if manu say,s so and fit the oven rigid BUT it needs an isolation valve before the two
