I am planning to run a radial circuit from a defunct 6mm cooker circuit. As I will attach a 2kw oven and a 2 kw washer as well as other smaller kitchen appliances I assume I will need a 32 amp fuse.
I was planning to run 2 separate spurs from 6mm in 2.5mm cable for washer/oven to ensure cable load not exceeded but do I need to use 4mm cable if I am using a 32amp MCB?
Will used a registered electrician to do the work but it impacts on how I do other work /obtain quotes
Any advice would be much appreciated.
