Running Speedfit externally and connecting to SVP
20 May 2013
Bristol
Hope someone can offer advice on this.
I have some 22mm Speedfit which comes directly from a shower pump and needs to go to waste. It will exit a dormer wall, turn 90° and connect to the vent stack (currently CI but will be replaced with plastic). From what I understand Speedfit isn't UV protected. I either have to protect the Speedfit running externally from UV or use another pipe method.
My preference is to use a different pipe but unsure what and how to connect the speedfit. Is it just a case of a copper coupler just before it exits the wall to outside, copper bend and then to the stack? How does the 22mm copper connect to the plastic stack?
Thanks.
